no...question...when under load and in the rpms....fan clutch type setup is the $hit... electric fans excel at cooling in the low engine rpms....@ idle etc.. because the fans normally run at 100% when on an so regardless of engine rpm the fans are moving air at 100%. I think the trick to the whole business is to have a great shroud setup, a good radiator and a fan clutch & fan that will move decent amounts of air at idle and low rpms....to include when the clutch is fully engaged at mid-range rpms.
that's one thing I noticed on the OEM yota fan clutch and fan....that it moved a good bit of air at idle and low rpms. When I had the I-6 I've let it run a long time with A/C on at idle in middle of summer to see what it would do....never onverheated and you could feel the air moving across the radiator from the grill area externally. Old school but very good.
I've seen some articles where people talk about modifing the GM fan clutch but I've never personally tried that. Good to have a high idle capability with A/C on for cooling purposes too.
