not sure about cost comparison but have you seen this? https://forum.ih8mud.com/200-series-cruisers/499039-new-radflo-suspension-review.html
how does radflo perform vs ome nitrocharged sport?
Do I really need UCAs if I'm looking at a 2.5" lift up front? I'm debating between this Radflo kit v. Icon fronts with OME rears. I hear the ICONs are more comfortable and that's what I need as my LC will spend most of its life in the urban sprawl. I also don't want a saggy rear end due to the front-end lift. Vielen dank.
http://www.radflo.com/store/product...ser-200-series-2-5″-performance-shock-system/
With this setup, does the rear get raised at all? I'm not seeing any longer springs for the raised front 2.5" height I'd want? Sorry for the newb question. Thanks.
ICON makes a rear shock to match with their front coil overs. They are more plush than the Radflos. You won't be disappointed for your intended purpose. I would highly recommend doing the UCAs...if you want 2.5" of lift, the UCAs will allow for better articulation and easier alignment. To finish it off, I would hunt down regular rate springs for the back with a wee bit of lift, it won't be saggy at all (unless you load it to the max).
