racing harness
Brisbane, Australia
i want 2 put a racing harness on my front seats but i want to no if i can put them on and also have the rear seat behind and able to put people in the back. can u install them onto the seat or do u need to have them put on the ground behind the seat?
you can't mount it to the seat...if the seat fails, which it will in a crash with the added load of a belt attached to the top, then the belt will do you no good and you will eat the steering wheel. mounting it to the floor will cause spinal compression in a crash because as you go foreward, the belt over your shoulder will be pulling you down. what you need is a horizontal bar right behind the seat at shoulder height. Simpson Racing equipment website is VERY specific on mounting:
I have my restraints mounted through the tops of my APC seats to the rollbar above me perpendicular to the street along with the lap belt to the floorboard. Should there be any changes made on mine?
the Simpson set-up is for extreme (racing) impacts. but you'll notice that all OEM 3 piont set-ups in every car built has the top mount at adult shoulder height or very slightly below. that is the optimal position.
that being said, i mounted mine to the roll bar as well.....i had it mounted to the floor behind me until i read about spinal compression, then i moved it to the roll bar because i thought that position would save my ass without paralyzing me.
I mounted my Crow belts
behind the seat using their special u-bolt setup and a backing plate. See it here:
this setup allows plenty of room for people in the back bench seat still.
that is exactly the way i had mine set up....then i changed it. i think it's fine for slow wheeling. but on the street the shoulder belt WILL hurt you in an accident. from SPARCOUSA website ( http://www.sparcousa.com/resourceFiles/16.pdf ) read pages 3 and 4.
and from momo-usa:
Mounting hardware is not included with harnesses, eyelets or bolts are included as shown in photos, installation varies with vehicles, modification may be required to install in some vehicles.
Warning
It is strongly recommended that the shoulder harnesses are fitted as close to horizontal as possible. It is a must that the angle of the shoulder harness does not exceed 45 degrees in relation to the theoretical horizontal axis of the mounting points. It is recommended that the harnesses be mounted to the fixing points suggested by the car manufacturer. The fixing points should always be reinforced by a steel plate fitted on the outer side of the car, not by welding or pop riveting. After an accident or a heavy crash, it is a must to replace the harnesses and carefully recheck their fixing points in the car. Belts do not have to be in contact with parts that damgae it. Should the belt show any wearing or cuts, it must be immediately replaced. Motor sports are dangerous. No warranty or representation is made as to product's ability to protect the user from any injury or death . The user assumes that risk. Some products are only legal for use on racing vehicles which may never be used upon a highway. check local laws
Diest Safety used to make a seat belt that went up to the roll bar, back down to your shoulder and then back at a 45 degree angle. I ran them for years. They were marketed towards Jeeps. I just checked their website and they were not there. Perhaps they have discontinued them for the aforementioned reason.
This company makes great belts with some interesteding features:
http://www.schrothracing.com/products/streetlegal/1576
-Stumbaugh
