Race removal tool?
Minnesota
Has anyone found a tool that isn't too expensive that works wells with removing the races out/in of the bearing hubs? I know there is the brass/hammer trick. I haven't tried yet but looks like using a hydraulic bearing press might be kinda tricky because of the angle.
-lispeej
hammer & punch..........:meh:
I used the brass drift and hammer. Works quite well just alternate sides as you hammer it out.
Now when you go to install new races Autozone has a bearing a race install kit in their tool loaner line that is great. Several tapered aluminum disks that you can screw onto an aluminum handle. When I installed the oil seals I just flipped the disk so the flat side was against the seal and it was great. I have used the socket method and custom made my own from wood or steel pipe in the past and the Autozone kit was just awesome I couldn't believe how well it worked. I found this kit during researching the axel overhaul on this site. Someone else had used it so I took their advice.
Hope this helps...
there are a few tricks, first for removing them you want to use a brass drift, I happen to be selling some in the classified section of mud bay, because I faced the same issue as you in the middle of doing a knuckle job
to install them I have heard of freezing the race, and make sure you put grease on it,, I will be trying this this weekend, others have reccomended using the old race, just grind it down a little and use it as a guide to tap the new one in,
I might get the autozone tool as it sounds good
You're not going to be reusing the races, so who cares how you get them out?
Hammer and old screwdriver for me.
Exactly. When putting new races back in I freeze them first and tap them in typically with a plastic/deadblow hammer. Freezing make them almost fall right in.
I've never tried the freezing trick, maybe I will next time.
My install tool is a brass hammer.
I used a socket extension to remove them and a brass drift from Northern Tool to install the new ones. They sell a pack of three different sizes for about $10. You can have them shipped to the store for free if you live by one.
looks like everybody agrees that using a hydraulic press isn't necessary. Ok.
I will take a trip to the store and get a few things I don't already have.
Thanks a bunch!!
Thanks a bunch!!
It was easy enough that I didn't drive over to the shop to use a press.
Is this a presidential candidate question?
Cool. All is good. I used the brass punch and big hammer method. Thanks to all that contributed.
