R150F in a bad way. Where to from here?
New Zealand
hey all, been meaning to join here for the past 15 years or do. used to be active on offroadexpress till life & work got in the way. then had a major health issue 3 years ago and am still learning how to function again.
first off, apologies for the wall of text. it's just how my head works unfortunately, try as I might I just can't do the short version.
anyways...Ive got a 1987 LJ71 that I swapped a 1uz into 20 something years ago, back when I was a 2nd year apprentice who hadn't yet learned why some things should be left to professionals.
suffice to say there were many things I should've differently - the past 22 years have been and endless cycle of having a working & mostly functional truck for a few months at a time, followed by a costly malfunction that sees it pushed into storage while I spend a year or so sulking about it rather than just fixing it properly.
Just off the top of my head, in the 20 years since I got it running it's covered all of 80 000km and it owes me roughly $22k. Admittedly I haven't been gentle with it by means...and it had 250 000km when I bought it.
I've overheated it several times, torched the wiring loom, fried the ECU, welded the battery to the bonnet, broken a couple of driveshafts, stripped 5 rear diffs, tried and cracked 3 sets of custom headers (before figuring out that 1.5mm mild steel wasnt a good idea), snapped a cambeltburst three different radiator....and only ever done one actual 4wd trip with it. also it's had a squeaking release bearing the whole damn time too.
like I say, it's never actually been "finished" per se. And I've only got myself to blame.
so with that background info, where I'm currently at is it's been basically parked since a few months before I ended up in hospital 3yrs ago. I've gotten it running a couple of times & done a few quick trips to town etc but haven't made it road legal.
I'm medically unfit to work for the time being so can't earn a wage...and it limits being able to buy the parts I need to fix things "the right way". I do, however, have a lot of free time. so "the wrong way" is a viable option...
The issue I'm up against is each time I drive it I remember just how bad a shape it's in - it's seriously lacking on just basic maintenance & upkeep. This time around I had to replace the fuel pump before it'd even start, as well as flush the rust from the tank....and that led to me realising I'd never gotten around to ever adding a prefilter to the line. oops. scratch one Bosch pump.
Normally when it first starts after sitting for a year or so, the release bearing screeches brutally for a minute or so till the grease frees up and starts working again. then it settles down to a constant, very audible squeaking. Which isn't too big a hassle once you get moving since the gearbox is worn badly enough now that it'll happily jump out of every gear except 3rd & reverse. Oil has been replaced regularly over the years (its always leaked, badly) and I've never found anything other than furry bits on the magnet. no teeth....
I'd have fixed it if not for the fact I didn't ever clearance the firewall enough to be able to undo any of the bellhousing bolts...and did such a horrendous job of the loom that I've never dared unplug it since it's all the same colour wire and all the terminals are crimped rather than soldered. Worse than Lucas wiring.
In other words I've spent the past 20 years putting off dealing with the mistakes I made in setting up the adapter plate spacing & fork pivot length before any of it even went into the frame. Once the engine & gearbox come out I'll have to redo basically everything before it can go back again.
Sorry, rambling again.
Basically what I have been trying to find out online, without much success, is whether or not I'm better to rebuild the stock R150F JDM gearbox (it's an odd model as far as I can tell), focus on replacing with it something like a R151 from a LN130 Surf, or potentially find out which parts if any could be interchanged from another Toyota box into the R150F.
The key thing here is cost. I simply cannot afford to do the sensible thing and give it to a specialist or to chunk $2.5k on a used unit. My eventual plan once I'm earning a wage again is to take it right apart and do everything it needs - seals, bearings & brakes etc. Until then I just need to be able to trust being able to leave my driveway if needs be without it dumping it's guts all over the road.
And turns out Google isn't much help when trying to learn if things can be done improperly. I'm hoping someone here might be able to give me some pointers on what might work in this situation - I don't need to be told to just spend X amount on it, sensible option or not.
So...yeah. as before, apologies for the giant post. I've tried to keep it brief but I'm fairly sure I've failed. sorry.
Cheers
(....pics for context. hah)
Have you considered - and I mean this with love in my heart - selling this bizarre project to some other sucker and getting a dependable car you can use while you get back on your feet?
not a chance. It's the one vehicle I've kept the longest, actually was my first decent 4x4. and I've never had it running long enough to get my money's worth out of it hah. That and it'd be worth so little as is, it's just not practical. It doesn't cost me any extra to store it since I'm already renting the space for my 20ft container, that's where it usually lives.
Believe me, I've sold everything else of value. bar my tools, my container & what's left of my dignity.
I think I need to add, there's no particular urgency to starting any repair on it. If I can't figure out a viable option before my focus shifts then it'll go back into its box and wait until I'm able to do things appropriately.
Honestly the vehicle itself is in the same state as any young mechanic's long term passion project ends up - functional, albeit with conditions, and they know every detail of it.
(come to think of it, it's usually marriage, parenthood or buying a home than finally forces them to get rid of it...each to their own, that's not my path in life)
If I hadn't gone into anything beyond the engine & gbox codes and a vague outline of the problem there'd be nothing "bizarre" about it.
Please don't let the long-form post influence your opinion of my question, again I'm trying my best but recovery from a TBI is a slow process. sorry.
Hi
First of: Thank you @nykril for sharing your story. It was one of the most touching introductions I ever read. Your lines, although not giving much personal details (which certainly are all private and totally fine to keep to yourself) nevertheless convey a lot of emotion as well as a lot of passion with your cruiser. All the best for your recovery.
To the matter of the cruisers gearbox. What is actually the issue with the gearbox?
What I got from your descriptin: a) squeaking bearing, b) jumping out of gears, c) leaking. You say it's worn, but no serious damage as far as the oil tells.
I actually have little knowledge on gearbox in general, but I think you have two options:
1. Disassemble the gearbox and check for wear / damage, replace parts as needed (and affordable). You may not end up with a perfect gearbox, but you might get some more life and joy out of it, to bridge time unless better options become available / affordable for you.
If you are lucky, you may get away with a throwout bearing, some synchro rings and some gaskets (or even gasket chaulk).(Others can probably better comment on the technical aspects of those symptoms and also the minimal cost and or availability and feasibility of used parts.)
The question to you would be: Do you have the capabilities and workplace resources to do a gearbox build on your own, or do you have somebody to help with those (as you can't afford a professional for that job).
2. You could try to find a better gearbox to swap in. The community here for sure is a good resource to find one sooner or later.
All the best to you. Good Luck Ralf
I can sympathize with your feelings about the vehicle. While mine has not been nearly the headache you've described, it has still presented me with plenty of frustrating issues, not to mention problems I created by doing things the wrong way at first and having to go back and fix them later.
With regards to your transmission issues, a rebuild won't be too difficult from a technical standpoint but you may be better off seeing if you can find a used transmission from a newer 1HZ powered 70-series. From 1999 and newer they used the R151f with the same split transfer case, but they're slightly longer so driveshaft lengths might need to be adjusted. The input shaft is also a bit longer, but you can get an aftermarket bell housing for them that will bolt directly to your 1UZ without the need for an adapter plate.
Hello,
I hope you get well. Do not rush your recovery.
They say that Cruiser owner ship is not cheap and requires a steady source of income. Well, there might be exceptions to that rule. On the other hand, being on a budget implies working on one system at a time, as much as funds allow. If I understand correctly, container rent supplies some money because every other valuable is long gone.
I have to ask this: do you have an FSM?
You can repair your transmission following the procedures set in the manual. Check parts availability. There are threads here about repairing/modifying transmissions like the one you have: it is worth making a search.
Since you have a 1UZ in there, sourcing an H150F transmission would be a good idea, as mentioned above. H15X transmissions are better at handling 1UZ engine's power. You may need a bell housing adapter.
The rest can be done after this.
Juan
Just my opinion.
