R12 AC hose source
Amarillo, TX
My AC hose pictured below needs to be replaced. According to Beno, the hose has been discontinued. Would prefer new over used, and I’m not interested in converting to R34. Any ideas on a different make/model hose that would work? Other ideas for a substitute? I did search, but might not be using the correct name for the part. Any help would be appreciated.
Thanks @Landseer. Sorry for my ignorance, but what kind of shops make custom hoses? Or maybe an online source? Thanks.
If you can't find someone local, you can send it to me and I can have it rebuilt, which basically involves cutting off the metal ends, brazing on new crimp fittings and replacing the rubber hose. Usually costs around $60 + shipping.
Thanks everyone. Another noob question: if I'm not running the AC, can I drive the truck without the hose or do I need to leave it parked?
You can run it. You might want to cover the connections where you take it off with a small piece of towel taped on. Just to keep it clean-ish.
Many thanks to all that responded. Very helpful.
I've had many custom high-pressure hoses made by a local place that services tractors. Just take in the old one, they'll match up the ends and build a new one for you. Mine ran like $25-30 for short hoses (up to 18-24") and they made them while I waited.
Lots of Napa stores have a line into a custom hose-maker as well and you can do it through them (for slightly more $.)
The shop might have to order metric fittings and that may take a few days.
The equipment to correctly build A/C hoses is not cheap. A decent manual crimper will run about $175 USD and that will work with most fittings with the crimp sleeves attached. Some fittings are unavailable, so you'll need a torch to be able to braze a new crimp sleeve onto the existing fitting. If you're dealing with aluminum fittings, you'll need special rod for that. A/C barrier hose typically comes in a 25 or 50 foot roll, probably average $80-100 for a 25' box.
You are right, but I already spend 100$ to a/c guy and my freon went again in next summer, now I know why.
I could check diameter of hoses myself but my car is far away from my 3032 miles( by plane or 6xxx by car)
Local shop in Moscow can sell hoses from 1 meter is a "Goodyear galaxy" 6,8,10,12 sizes, they will fit to my stock R12 fittings?
