Quick Steering column removal question...
Bay Area California
Looked through other threads real quick couldn’t find it but where do I dis-attach this steering column right here? ... obviously I took off 3 bolts on firewall...
40 series? that is not a stock column.
looks like you'll need to disconnect the rag joint and the unit should pull out into the cab
It’s a steering column from like an 84 runner
I just a new column for my year... rag joint? Meaning
Disconnected rag joint ... took off bolts on inner side triangular firewall attachment & shroud. Question 🙋 - do I need to prybar at the shroud to free it off firewall or is there a disconnect in the steering column to let go of that larger side in engine compartment trying to pull through?
