Hey all,
My 6/1975 FJ40 has never had a working original oil pressure gauge. The PO had simply installed a mechanical one when he converted to a V8.
I was playing around with the wiring harness yesterday and located the original electric oil pressure sender connector. I confirmed that the original gauge works using the test-light procedure outlined in @bj40green post (thanks Rudi!) here:
Clusters, Gauges, Speedo & Odo meters
The gauge deflected when I grounded the connector though a test light, so I'm assuming it should function if connected to the proper sending unit.
The only confusing part is - the terminal at the end of the wire isn't correct for the stock pressure sender. As far as I can tell, there should be a special spade connector that slides over the top of the sending unit. My connector (below) has a definite "Toyota" connector, but it's not the appropriate plug.
Was there a separate "pigtail" that connected this plug to the sender?
This plug is low on the driver's side.
@Coolerman - I'm hoping for your expertise here! Also - I'm hoping you have the stock "slide on" connector available.
I'll probably mount a stock Toyota sender down at the port above the oil filter on my V8, and keep the (more useful) mechanical gauge mounted at the back of the block by the distributor. That way, I'll have a fully functioning dash!
What amazes me is that some of these hacks will work for years!
