I have developed a small drip near my drain plug. The obvious thought is that i must have left off the gasket and my truck needs one. But before i pull the drain plug i want to be prepared for the worst case situation. That would be that some how i messed up the threads. If i need to re thread it, any know if the lower oil pan can be removed by just removing all the bolts? Is there room to slide it out with out doing anything funny like lifting the motor?
PS any know the thread size in case i need a tap?
I figure i might be a good idea to have the pan gasket and the right sized tap on hand just in case the threads are bad.
