quick little question
City that rhymes with fun
i have the chance to purchase a F engine,trans,tranfercase. out of an 72 fj55. will this bolt directly into my 67 fj40?
cmon people help me out please............... i dont wanna miss out on this sweet deal.
Yep. No problemo
sweet.......... im just waiting on compression numbers but it all sounds pretty good and for $175 for just the engine i feel its a good deal. thanks
so let me gets this right it will be a direct bolt in for everything? motor/trans and transfer.
NOTHING is a "BOLT IN/ON" deal....EVER.
You may run into something.....but if everything is stock on your truck, and nothing has been messed with on the other one, then you will only need to cut holes in your floor for the trans and tcase shifter canes, or swap you trans and tcase controls over to the new components.
Drive shaft fasteners are larger on a 1972 compared to a 1967, iirc.....bolt pattern is the same however.
:beer:
yes i agree with you poser bout bolt on, i was just more concerned with the mounts being in the same place. im just gonna stick the, motor,tranny,trans in all together....... thanks for the input
:beer:
In other words, while it may be a 'quick' little question, it may not be a quick little answer!;)
Manifolds and carb are different. Better make sure you're getting them. Carb, linkage and air cleaner are different. See answer above
Motor mount brackets on bellhousing are VERY DIFFERENT, but can be swapped. Hope you've still got yours.
Clutch fork generally exits on the OPPOSITE side on a 55 from a 40, and you will need to disassemble the tranny from the bellhousing to swap it over from the passenger side [where it was on the 55] to the driver [where you need it on your 40.]
Thats all I can remember at midnight!
Best
Mark A.
well im probly just gonna swap engines. the guy im gettin all the stuff from suggested i just take it all together and drop it in. i knew there was more to it, so i thought id check with all you here. how difficult will it be too separate the motor from the tranny?
It can range from real easy under normal circumstances to real hard if the pilot bearing is siezed. If you have to ask this, you might want to reconsider your decision to take all this on. Not trying to be a prick, but this is a lot of work even if there are no surprises.
i only asked becasue a friend warned me bout it. just cause he has a bad expirience with a mustang(yuk). both vehicles are currently running and driving fine. im definetly up for the challenge. its the only way im gonna learn, and i hope you guys are there to help me out.........
