quick help please!
Yes I am a newb but I searched here and on google for ten minutes and couldn't find the answer. We just got done rebuilding the front axle and used just shy of 3 pints of 90W to fill it. But it's still not full. We do not have the manual nor do we have any more gear oil. Now I am sure that 3 pints is enough for now, right? How much gear oil does the front axle take? Thanks.
My fsm says 2.9 quarts for the front differential.
Fill it until it runs out the fill plug. 3 pints is not nearly enough if you drained during the rebuild.
Drive the hell out of it ...
The front diff is NOT a load bearing differential... Only when in 4WD.
The bearings are taking the load and they have NOTHING to do with the differential....
Unless you have some weird unit that uses Gear Oil to lube your knuckle bearings....
The 80-Series are full-time 4WD. If the front wheels are turning the front diff is turning. I think that would qualify as being load bearing and driving it half full of gear oil is not recommended.
-B-
I agree with those that stated not to drive the 80 till you get more fluid in that diff :)
As for searching, here is a link to one of the most important and helpful sections of the 80s section in MUD:
FAQ for 80/LX450
Subscribe to it, read it (many times), learn it, live it :D. You never know when something you read in there will help you out when you least expect it and when you are likely away from a computer (i.e. starting problems, why you can't shift into drive from parkk, etc). Many of us even print out certain parts and keep them in our rigs at all times.
Oh, and you can ALWAYS find it right at the top of the 80s section in the sticky threads :cheers:
Hmm pints and quarts I usually by 4 QUARTS when I am filling my diffs. It takes more than 3 bottles but less than 4.
I then drink a pint
I then drink a pint
Oops. I meant quarts not pints. I was real tired last night. We are going to get another two quarts today after work and fill it. He's not driving it in the meantime.
Thanks again guys.
My Bad on the Axle... It didn't occurr to me that it was a full time axle. I wasn't paying attention to the forum in the post Iwas on the recent posts link....
If yours takes 3.75 quarts and you have 3 quarts in it you will be fine to drive it to the store and get more.
In reality if your ring hear is dipping in the oil and it's lubing things you will be fine in the short term.
Thanks. That was my thinking. One more quart and I'll be good. Thanks everyone for the replys. I'm not new to cars so I know that you fill it until it comes out the fill cap. But if you read my first post, I was out of fluid and wondering if 3 quarts was enough to drive it short distances.
The 2 of us that recommended not driving did so because you originally said pints, not quarts.
-B-
