Krondor
Trying to find out where to bold the white cable up to on a 1965 gear reduction starter upgrade.
Same bolt / terminal as the battery.I think he’s asking where on that starter the white wire bolts to. I’m curious as well based on the pic it isn’t obvious which bolt is the connection and which are structural bolts. It should bolt to the same location the positive battery cable bolts to, but I don’t see that. Is that ground cable connected to the starter in the right spot? The ground usually connects to a bolt that connects the starter to the bellhousing. What’s at the end of that heavy blue wire?
Dang @kerplunk I didn't even see that wire with the red end,. Yeah, that's the connection point, good eye. OP, what @kerplunk said.
Matt @ToyotaMatt early wire harnesses (like his '65) have just the plain white W wire for harness power, and there is no fusible link either. @1969FJ nailed it with his shown schematic. The WB and fusible links came in later.
Thanks guys for the help! It’s amazing what knowledge this community has. There is a terminal on the GR starter where the power cable bolts to it that I will run it to. Is there a benefit of running a fusible link here like the later models have?
