OK,
Had the morning coffee and found some ambition.
If you have been neglecting your front end or just want to spend some quality time with her without really tearing her apart try this.
Put her on jack stands, this makes it simple when you want to steer the wheels in order to remove the 10mm bolts.
Carefully loosen the bolts as they can easily break thus causing you minor delays.
If you are unsure of the order do one side at a time laying the parts out in order of removal.
Now lets put her back:
Steel split ring near 12:00 oclock position, use fresh grease to glue in place
http://img69.imageshack.us/img69/2634/1002700qf0.jpg
Next the rubber seal: Cut and thread around axle keeping the ends clean as they will be put together with a quality "0-Ring" glue available at any parts store.
http://img239.imageshack.us/img239/4365/1002701mx9.jpg
Now the felt, same procedure, keeping clean and glueing, I used Seal All for this but surely anything handy will suffice.
http://img209.imageshack.us/img209/8858/1002702hq5.jpg
Button her up, grease her, go to the beer store, and here is what she looks like.
http://img213.imageshack.us/img213/5055/1002699xq4.jpg
Notice the fresh clean grease all around? Not dry, rusty, nor crud.
Since I am lazy I cheat by using this, a greaseable birf, remove dust cap and pump till fresh grease is visible at square plug/Prv location in above photo.
http://img515.imageshack.us/img515/5285/1001988dq0.jpg
Now time for this!
http://img218.imageshack.us/img218/3470/kipawamike9ppqp5.jpg
While saving this from our short sighted Gov't
http://img279.imageshack.us/img279/8743/rallyposteroneyellow2xm.jpg
Now time for this!
Then it would be handy.
