Quick EGR question
Boise, Idaho
I am diagosing a P0402 code, excessive EGR. My question is, is the EGR valve spring loaded closed? As in, if no vacuum applied on either port, it will be closed?
And just so I know, there is a vacuum diaphragm in the valve. The hose on the top of the EGR is controlled by the VSV, and the bottom by the EGR modulator. Are these in balance and canceling each other at idle? Hence the valve is closed at idle?
The EGR valve is spring loaded normally closed.
The VSV is normally open.
Vacuum flows thru the circuit all the time.
The VSV closes allowing the modulator to control vacuum to the EGR valve.
Does the VSV get input from the EGT sensor and the TVV sensor for closing, based on antifreeze and exhaust gas temp?
The hose at the bottom of the EGR valve is the exhaust backpressure feed for the modulator.
The ECM (computer) is controlling the VSV based on temperature, load, RPM, etc.
The EGT sensor provides feedback to the ECM, telling it whether the EGR Valve is open and flowing or not.
Still fighting this weird issue. So today's troubleshooting effort was this: I pulled the vacuum line between the VSV and the top of the EGR. Upon enfine start, it runs smooth and idles fine. There is vacuum on the line from the VSV. When I plug the line back into the EGR, the engine rpm drops and the rough running starts again.
Also, I have no vacuum at idle on line "R" to the modulator. i do at any speed above idle, but not at idle.
Also, when I unplug the r line on the modulator and block the R port on the modulator, the engine dies.
