Less than 5 psi it will cope ok, but wont be optimum for the $ spent.
Intercooled and with premium ULP you can run 10 psi of boost, if you run an aftermarket piggy back to adjust fuel and ing timing, but you will have to run extra injectors on a pre 95 unit, and perhaps fuel pump as well, and a rising rate fuel reg.
How much you spend, and how much pwer you want for your money, vs cost makes the difference in how far you go with this.
5 psi and no tune, shouldnt be an issue with detonation, as long as the head hasnt been machined previously, and yyou should see around 200 hp at the wheels, and about 15-30% increase in fual usage for the same driving, but 10 psi, piggy back, fuel pump and rising rate fuel reg and you should see 300 hp at the wheels, and an improvement in economy for the same driving.
Of course driving it harder, and using all the extra power will see an increase in fuel usage also.
