Question For You Sniper Guys
Miami, FL
Is the regulator on the Sniper 2300 electronically controlled or is a simple mechanical regulator? The reason I ask. If the Sniper is mounted and the fuel system is complete, can you simply jump the pump and circulate fuel to test for leaks before moving on to the wiring?
It’s a mechanical regulator.
When you power the unit for the first time, it will actually run the pump continuously (to prime the system I’m sure) until you set it up. Don’t even have to manually power the pump.
Are you in the middle of an install now?
Thanks for responding.
Yes. Started the install a few days ago and finished the fuel system. I just now jumped the pump and it picked up the prime pretty quick but then sounded like it had quite a load on it like it was dead headed. This was all in about 4 or 5 seconds and I shut it down. Ran to the other side where the 0-100 gauge is and it was pegged. With the pump off it was staying pegged. Loosened a line on the return and it was empty. Had to loosen a line on the discharge side of the pump and the pressure dropped to 0. I've run hard lines most of the way except for passenger side, engine to frame where hose allows for engine movement.
Could there be a solenoid in the unit somewhere?.
I guess I should just get it wired up and complete the install.
No leaks on the supply side anyway.
Ok. I read on the Holley forum that testing like I did is fine and the mechanical regulator should function at 60 psi. So I must have a bad fuel regulator. That’s nice. Brand new out of the box. On the Holley forum I see it’s not uncommon. Looks like they send you the parts and you fix it yourself. I’ll call tech support Monday morning. If I had read about people having bad regulators I would have put a gauge and air pressure to it when it was first delivered to see if the regulator functioned properly and at 60 psi.
I also saw on the Holley forum where a few folks have given up on their Snipers and went back to a carbs because of reliability issues. I know those may represent a small percentage, but I am starting to get a queasy feeling about this Sniper before I even get it installed.
I hope it all works out.
I installed and ran the 2300. No issues, best upgrade Ive ever done.
Keep on trucking...
Just spoke with Holley support. Gave a quick description of the problem and he immediately asked for my address and is sending a new regulator. Sounded very routine like it’s common. Oh well, on to the electrical. Guess I should start an actual install thread. I hope the next obstacle isn’t that potential hurricane that’s brewing up out there.
Hey Steamer, I also had a bad FPR out of the box, but swapped it out and it fixed the problem.
I posted a little at the Holley Forum and maybe it will help a little? post #11
Anyway, more info...
Brian, I read that. didn't know it was you. New one is on the way and won't get here soon enough lol. Just about to start an install thread with a better title that may help searchers down the road.
to add add to a question for the sniper guys...if you are running the under the seat fuel tank and a rear fuel tank and were planning the high pressure fuel pump in rear fuel tank how do you run the gas lines for the under the seat tank? I am guessing you feed the front to the rear tank - is there a best way to do this?
Use an inline pump to transfer the fuel from one to the other. If you’re using an in-tank pump to supply the Sniper, that should leave some unused supply or return connections to fill the tank from.
