Question for you audio guys
Tigard Oregon
Heres the scene:
97 LX450
Alpine 6 1/2" component system Type R
I found a way to fit the 6 1/2" in the door, now my question is the wire that goes to the stock speaker. Is it intended for subwoofer only?, since the tweeter is in the dash? Because I was thinking of just installing the subwoofer,the crossover, and tweeter in the door, but I was thinking that Toyota might have split the signal and sent the lows to the door sub and the highs to the dash tweeter.
If they did split it, I am thinking either I need to either run wire from my door(where my new tweeter is) to the dash and disconnect the old tweeter and hook it up there and not use the crossovers that are with my component system.
Anyone have any experience with this?
not entirely sure, but i think the factory stuff is running full range to the door and dash. i would definatly use the crossovers that came with the speakers, since they are designed to work together. the only issue you may have is the factory amp may or may not be strong enough to really make those speakers sing.
just my 2cents..
I figured the stock amp wasnt going to push much to the components, but I will dive into that later. I have a Alpine amp too. That would great if it was full-range to both, make it easy on me, someone should chime in soon with certainty.
The front door and dash speaker are both run off of the same wires from the amp. According the diagram, they are paralleled at the front dash speakers. This could easily be verified because if so, there will be 4 wires total at each dash speaker, + and - from the amp and + and - to the door speaker. Generally, it is not a good idea to mount crossover's in doors. They can be damaged from the elements and the constant slamming of doors.
The front dash speakers are probably crossed over with a tiny cap, not electronicaly through the amp.
I already tied in the subwoofer in the door through the crossover and it works fine. I got the color code from the FSM on the + and - for the door speaker. I havent opened up the dash speaker, and it from what you are telling me it doesnt even need to be done, unless I replace that speaker.
So why have I been reading that the doors are subs and the dash are tweeters then? Or am I reading it wrong? Or it could be Toyota ran wires and they could be used for either a sub and tweeter or a regular coaxial.
If your new woofer and tweeter are both in the door, you will want to disconnect the dash speakers at the very least.
Speakers can be crossed over either electronically or passively. passively is much less expensive as it allows all the speakers for a single channel to be connected to single amplifier channel.
As far as subwoofers, there are no legitimate stock subwoofers in our vehicles. They can be referred to as the woofers when part of a two way system though;)
and the reason for disconnecting the dash speakers? Im not at all familiar with how crossovers work, Im just going by the directions on the crossover.
Let me throw this out there since I think we have the component system figured out. How do I integrate the Alpine amp into the equation? I have read on here that the way Toyota set up it all up with the factory amp it makes things alot more difficult.
I completely removed the factory amp system in my truck. Ran new wires from an aftermarket stereo harness to a 4-channel amp under the driver's seat and wires from it to the Kenwood door speakers.
Works like a charm :D
I removed all the factory stuff as well. Currently just running HU power to the aftermarket door speaks. I have PG amp and W7 sub ready for install, but can't find a good place for the large beast.
and the reason for disconnecting the dash speakers? .
So those old crappy speakers don't take away from the quality sound that the units you've just gone to the trouble of installing produce;)
I have seen posts on how others have done it but I don't remember if they intercepted the signal before it got to the factory amp or...connected to the speaker outputs of the factory amp. The best solution since you've gone this far is to do what the others have recommended and replace the factory head unit.
So can I just replace the factory amp with the Alpine? Of course I know it wont fit, but use the same inputs and outputs? I bet its not that simple. I still have the factory stereo and CD changer(that works). Im thinking all or nothing. Tools R Us had mentioned to me once that Toyota systems dont play well with others and I might run into prolems, we will have to see. As long as my Alpine components sound o.k. then im fine for now, with or without the Alpine amp.
factory head unit will be replaced in the near future, but im wanting one that does topo navigation, so I will have to wait awhile till i get the coin.
Maybe some will chime in and let me know about the amp swap. Im not going to mess around with it too much right now unless im for sure, Im going to Cruise Moab and will need music.
just reiterating that half-system installs are tricky beasts. not sure if you have already put in the amp and components, but I would suggest letting them sit until you have everything you need. I am just about to install my system, and have been collecting various parts on and off for 2 months. I have:
Alpine 9833 HU
PG RSd 6.5 comps up front
Alpine Type S 5.25 rear doors
RE Audio SE 10" sub
Crossfire VR1000D
Crossfire VR300
lots of wiring
I have the 6 1/2" subwoofers, tweeters, and the crossovers in the doors already. The amp is sitting on the workbench till I get some more info gathered here on the board about installing it.
