Hi. I just got a trailer and have a couple of questions regarding charging the trailer batteries.
Tow vehicle has a starting battery and an AGM battery linked via a selectable 200A solenoid. The second battery runs the winch and all accesories so the starting battery is used only for fully stock applications.
I have #4 cables already routed from the second battery to the back of the vehicle to power my fridge, compressor, and rack mounted aux lights.
The trailer has two Optima blue tops. How should I charge them? I believe the "standard" method is to route #10 wires from the main battery to the 7pin RV plug for trickle charging the trailer batteries. The trailer is already setup up for this canfiguration, but the tow vehicle is not.
The other method (I think) would be to have two plugs - one for the standard RV 7pin and another for the #4 cables. That way the two trailers batteries would essentially be connected to the two vehicle's second battery and they could be brought in and out of the charge loop by my 200A solenoid.
I read somewhere that AGM batteries allow current to move very quickly and gell (optima) batteris require a very slow charge. if the AGM and optimas were linked, would I risk damaging the optimas if they were low on charge and the AGM rapidly flooded them with current?
So - which method is preferable? can I wire both methods? Any opions or experiences. Thanks!
