Question about rear control arms (upper mostly).
Alabama
Ok if you were ultimately aiming to do a 6" lift but are going to piece it together (ie not order a kit like Slee sells).
Most people say that at anything 4" or less the upper rear control arms aren't an issue.
For those running 6"+ I assume most are running Slee's adjustable arms at 459 bucks... but MAF sells what appears to be a 4" drop bracket (or for 4" of lift) for 100 bucks.
If you are running ~6" of lift and drop the rear upper arm 4" then would it be correct to assume that it is close to the angle it would be operating at with 2" of lift which is a height at which no one worries about it?
Just trying to figure out if the extra 359 dollars is really necessary or worth it.
Also does anyone bother with the rear lower control arms? I noticed MAF sells brackets for it as well, but the 4" and 6" Slee kits make no provisions for adjusting it.
Thanks
Sam
One more facet to consider is that if at some point you find yourself with driveshaft vibrations, you will probably decide to go with a DC driveshaft. If you do, you will want to have the adjustability to point the pinion flange directly at the transfer output flange. Standard u-joint driveshafts "prefer" different geometry than a DC driveshaft.
do many people running 6" lifts end up going with a dc rear also?
welding is something I would like to learn to do, welding control arms on my truck is not where I want to start... haha
I don't have a DC rear. Can't speak for anyone else, but I don't think it's common.
Find a friend who welds, or take it to a shop, might save a few bucks by re-using the parts you're gonna throw away anyway.
-Spike
Been there done that, infact if you want I'll sell you the POS set of MAF upper arm drop brackets I wasted $100 on. They are meant to be used with the complete drop bracket kit, but being MAF they don't care to fully inform the buyer.
I went with the weld in upper arm adjusters from Slee. At first I thought they were not worth the $220 but WOW they are supper nice pieces of machining and VERY beefy!
I meticulously matched the rear pinion to the t-case with the adjusters, 3.5* if I remember correctly. Still at freeway speeds when I'd let off the gas my rear shaft sounded like a meat grinder. I also had new u-joints put in, so I can't imagine anyone getting away without a rear DC shaft on a 6" lift. If you search around you'll find a thread I started about making DC front and rear shafts. I'll admit my posts in that thread are sort of confusing but I understood it. :D
The downside of a 6" lift with the rear pinion properly set for a DC shaft is that the rear springs get a whole lot of bow in them. I'm really impressed with how strong and well made the Slee springs are though. I anticipated the springs to start sagging very fast from all the extra bow, but they are still holding up well at 25 1/4" on both rear fenders.
Been there and done that, too. Forget the MAF brackets.
