Quart every 800 miles?
Roger that. The people at ACC recommend that the guides be done at the same time as the valve stem seals (and/or head gasket) as they've apparently seen significant wear in the guides, just wondering what others have found.
Also the machine shop they work with requires guides to be replaced for warranty reasons.
I have crawled under my truck in the past and I couldn't find any substantial leaks but maybe it's time to crawl back under and look harder... I'm leaning toward switching from Valvoline 20w-50 to Rotella 15w-40 because it seems that many members have decreased fuel consumotion with this oil and a wix filter
If that doesn't work then I suppose I will be performing a leak down test and possibly replacing the stem seals since it has been recommended that this is a common culprit. Im just hoping I don't need a rebuild just yet because I haven't quite got the pockets to do so right now
Mine does a little blue smoke on startup, and the front cover leaks at hwy speed. I'd never have found it if I didn't band mynhead on the panhard bar and look up. Mine is the same, roughly a qt/1000mi.
So, I burn that much also--no leaks, replaced PCV twice, tried multiple weights and brands of oil over the years. I get a bit of smoke and stinky exhaust at idle and then a big puff of blue smoke when taking off after idling for several minutes. Otherwise, she runs perfect. Is this indicative of the stem seals?
