put the CB in the dash
Seattle
I recently put my Cb built into the dash. I was able to cut and fabricate the original ash tray plate-mount to hold the Cb in place using the stock holes. I have a bunch of pics of installation i can post later if any ones interested. It was a really easy and fast job and keeps the Cb from bouncing around the cab.
mike
well id love to see a few steps in between u crackin the dash and the finale results, would love to see how it looks finished. thanks
I did the same thing with the same radio. This radio, from Radio Shack, is much smaller than the Uniden, hence less material to remove. I got the Uniden for sale if anyone needs one!
Ali
theres to holes on each side of the CB that are threaded to mount it on there universal mount i spot welded a washer on each side in the right location to that the Cb was also attached that way as well however i dont think it would be absolutly needed as it was held really tightly by just the sides of the ash tray mount.
Mike,
Where did you decide to mount your antenna, and what length of coax did it require?
Thanks,
CJ
i just got a new ARB front bummper so thats where the antenna is and the cable length is exactly 15 for a dash to right hand side mount routed through the hole in the fire wall on the left upper side above the pedals. it will give you some slack to its a nice fit.
