Pusher cooling fans?
So Im having some difficulty with cooling my 2f with air conditioning when the truck is idling and its really hot out. I was running the mechanical fan with a brand new aisin fan clutch but the fan hit the radiator when the suspension was really flexed and therefore the chassis was flexed pretty good too. I had spaced the fan out a bit from the water pump so it would be a little further away from hitting the vintage air ac compressor. The ends of my fan blades had been trimmed about 1/2" when I was out on the trail and found I had a bad motor mount. I trimmed the fan blades on the trail to keep the fan from hitting the shroud. I have since replaced the motor mounts but not the fan. So here are my thoughts:
I can install a new fan blade with the clutch without the spacer. I will have to trim the corners of the fan blades a lot to comfortably clear the compressor but this will move the fan 1/4" away from the radiator so I should have over 1/2" distance between the fan and the radiator. With the new fan blade I should gain about another inch in diameter of fan blade. Looking at the grill though, if I remove the toyota badge, I can install 2 electric 8" pusher fans inside of the bib and have them click on when the ac comes on giving another 1400cfm of air flow when the AC is on, the bummer is I will lose my toyota badge, but should have ice cold ac at low speeds offroad and a cool motor. The fans are only 40 bucks for the pair. Do you guys think this is a good idea? Or do you think its overkill? Before I killed the radiator, the AC was not ice cold at slow speeds, but cool enough to make the cabin a lot more comfortable.
i took off my bib and and went to headlight rings and gained about 23 inches of air flow to cool my 501 caddy powered fj40 .i think the early fj40s came this way before the bib.it doesnt matter how many fans you have you can only get so much air through the opening
It only happens when its hot out and Im idling for about 20 minutes with the AC on and the truck isn't moving, when Im moving it cools really well.
Be careful with the pusher ratings - most "pusher" fans are just a reversed puller. The efficiency/cfm rating is usually far lower as a pusher. So a fan rated at 1500cfm and is a pusher/puller - that rating is as a puller, and as a pusher could be much less.
