I have the 4x4 labs rear. You remove the oem rear bumper. Then you have to cut the rear of the frame off. This sounds terrible and did make me nervious. But it is the only way to have a bumper that is so tucked in and well shaped. Its the reason the 4x4 labs works so well and makes such a great departure angle. I just used a sawzal. The cutting took 5 min.Hey guys how did you get access to the top two holes on the driver side to install the M8 rivenuts for the wing support bracket? Was your drill at an angle vs perpendicular to the frame? It’s a tight spot in there to bore those holes out, right?
Once the rear is trimmed the 4x4 labs bolts right up to oem bolt holes if i remember correctly.
