PUMA compressor / tank mounting options
NYC / CT
I just picked up a PUMA, have looked over many PUMA mounting threads and realizing it's a bit large and heavy. I have drawers so I can mount it to the top of the drawers, but I'd like to explore separating the tank and the compressor - put one under the hood and the other somewhere else. Maybe some ports on the bumper or somewhere easily accessible.
Has anyone recently done this on an 80? I can't seem to find it and would love some advice. Would be awesome to have it clean and internal, mounted low.
Thanks!
James
I wanted a Puma but realized I could save some room and meet my typical need with the ViAir......
That said it likely won't work as fast or be able to seat a bead but that's the compomise....
right now I'm a bit skeptical about the range of uses of the PUMA. if it's not enough something smaller makes way more sense. going to go to the shop and test out a bunch of tools before I embark on this. if it passes, I hope to do something fairly clean that makes sense and doesn't rattle
Puma setup nets my air up time on 37's from 18 up to 36 psi is 2 minutes flat for each tire. I can do unlimited number of tires depending on how many friends park close to me. Unit is 4 years old and gets used very often.
CO2 user for years and just switched out for a PUMA and LandCruiserPhil's mount. Couldn't be happier with both. Like the fact that so long as I've got power that I can air up. Only ran out of CO2 twice in all the years with it, but the constant 'do I have enough for this trip' got me to change...that and the fact that the closest place to get CO2 moved farther away! Phil's mount is very sturdy too!
Used the Puma to reseat a tire yesterday when wheeling. Puma is mounted to the LCP Puma/interior tire carrier mount.
