- Joined
- Dec 2, 2004
- Threads
- 126
- Messages
- 821
I've started pulling the transmission and transfer case.
The manual is sketchy when it says to disconnect the transfer case lever, it's quite a system of linkages, what do I remove?
After pulling the bash plate, I noticed quite a bit of oil on the rear face of the transfer case. It's not the same black engine oil I know is coming from the main seal, rather what looks like clean gear oil. Given that it was just changed, I'm wondering if it's spillage from the shop, or another seeping seal somewhere. In any case, I cleaned everything off and I'll watch to see what might be leaking. I suppose Toyota must sell gasket kits for the transfer case?
Also, is there a technique for removing the 4WD and reverse switch plugs from the case? I don;t just want to haul on them.
....zing zing zing zing zing and I was done...10 seconds.
