Pulling to the left when braking?
Yes, the usual suspension mods but the correct set up with correction. This is a fairly new issue. I hit the brakes and have to steer right to keep it in a straight line. It only pulls when the brakes are applied.
Any mods to the truck? Lack of caster correction?
If not, a seized caliper would be the first guess.
Tires all correct pressure?
If you bought a place that does free rotate and balance, I would do this first. Next potentially alignment or brake/rotor wear.
Seems that you may need to bleed the brakes..and also check for any leaks on the brake hoses by the caliper..
I agree with the seized caliper theary. Unless the p/o used non toyota pads, then this would be suspect also. I "Always" use Toy pads.
I would think on the siezed caliper thing. Check brake pad wear on each side.
Too many think of pad wear as the end-all. More important is caliper movement. A critical part of disc brake service is caliper lubrication and movement. Caliper lube has to be a very high temp lube. If a caliper gets sticky the truck will pull in that direction, or even in the opposite direction when braking. Most part-time techs, when working on brakes assume that the high pressures involved will overcome sticky parts. But they will not! A sticking caliper will cause a mess! All moving parts of a brake caliper need to be cleaned out and lubed with the correct type of grease every time that the pads are replaced. As a pro for 20+ years, I know that just replacing pads will not do. Everything that moves must be lubed properly.
Now a word to those who do this for a living: You get paid 1 full hour to do this brake job without resurfacing the rotors. A full hour to simply replace the brake pads. A pox on you, an absolute shame on your family, if you cannot take the time to do it right! You must lube the caliper, lube every slider, do it the right way. Your reputation is in the balance! It takes you 15 minutes to be sloppy, and 30 minutes to do it right. You get paid 1 hour, do it right!
I have done it for a living for 20 years and I will accept nothing less!
LOL, man, you have me ready to take up arms and head for my local Brake Check!
I totally agree. This is a total different thread subject but some of the dishonesty out there in the automotive repair world is amazing. Even the dealerships are quite guilty of it. They skip the important little steps to get one more unit out the door and another in the shop.
Brakes are one area I've never spent much time on. Should I just follow the steps in the manual to lube and service the calipers? Any consumable parts besides the pads that I should replace? I'm about a :banana: :banana: tech level.
