Pulling to the left under braking
I noticed she was really pulling left, esp under hard braking. I mean enough to induce a spin if it were a little snowy (which it has been.) So I went around and adjusted all the drums so they were just barely backed out from dragging on all 4 wheels. It got worse. So I backed off the front left, then off the rear left. Now its worse?!?!
Seems intuitive that if its pulling left under braking, the left brakes are engaging first and the fix would be to back them off a little. Am I off here? Another suggestion, please?
thanks
john
If you haven't, pull the drums to see if there is a fluid leak causing the shoes to grab.
I would also check to see that there all actually moving, you may have one stuck via rust.
Matt
Are the left and right brakes adjusted evenly? When I had this problem, mine were adjusted evenly but the drums themselves were way out of round.
The reason for this is that the brake pressure goes to the front left tire first. It happens to mine under extreme braking conditons. Take the drums off and inspect them or have them inspected and tuned. It should normally have the "stomp steer" because the first tire the fluid pressure reaches when braking is the front left. If anything, increase the right side rear all the way, and back the left front off slightly. Remember to pump if caught on ice, and if you find yourself pointed in a different direction than you are headed, release the brakes, hit the clutch and turn into the skid... personal experiences say that bad things will happen otherwise!!
That's pretty much a load of hoo-ey. If it were true then 4 wheel disk brakes (which are none adjustable) would always be pulling to one side.
Follow the steps listed earlier and your pulling problem will be solved.
Definitely. Hydraulic fluid is essentially non-compressable under the pressures in automotive brakes. Pressure transfers equally throughout the sytem, assuming no air or leaks.
The drums are freshly-turned and the brakes are already bedded-in (but new-ish pads.)
No fluid leaks.
All the brake cylinders are dry and the adusters work.
Flesh fluid and bled.
It does need an alignment, but it drives fairly straight when I let go of the wheel. Maybe hard braking exaggerates a marginal mis-alignment?
I had the same problem with my 74. two of my wheel cylinders were stuck which made things pretty interesting under hard braking. I rebuilt all of my wheel cylinders and the problem is gone. I don't think the kits cost very much at your local auto parts store, probably under 10$ per cylinder. You could also replace the problem cylinder with a reman unit for about 100$.
Rich,
Thanks. I am hoping not to have to pull the cylinders...I have no leaking and the adjusters turn and function properly...
any other ideas?
thanks!
The adjusters are separate and will still work if the cylinders are stuck, also my cylinders weren't leaking, they just had a bunch of rust and gunk inside them that stopped the pistons from moving.
They really aren't that hard to rebuild and once you get set up to do one you might as well do all of them since they are all in almost the same condition and you have to bleed the system after anyway. You might be able to narrow it down to which cylinder is stuck by removing the drums and trying to compress each side of each cylinder by hand by pushing on the shoes. The pistons in the cyliders should spring back if you can press them in. If one doesn't move, crack the bleeder on that cylinder and try and push it in making sure you bleed the system after this may free it up but it will need to be replaced or rebuilt. I would start with the right side if it is pulling left.
don't push the brake pedal with the drums and pads off or you could pop a piston right out of a wheel cylinder.
Good luck
