Pulling the rug!!!!
LFD2037
TEXAS LEXUS!
Wax., TEXAS
Going to yank all the carpet out to wash it at the car wash. Question:
What do I do with the backing when it doesn't come out uniformly?
I had a leak a few months ago in the PS floorboard. When I pulled it up to dry it out, the insulating backing of the carpet half ass pulled up and half assed stayed stuck to the truck pan. What's the best way to deal with this when I pull the carpet from the front 3/4 of the rig?
My prev 80 I pulled all the horsehair mat from the body side & the bulk of the part left stuck to carpet - I did a decent wash of floor & hit it light with scotchbrite pads to give tooth for Dynamat / generic of it. It only covered 2/3 the flooring between the fr & back footwells & tunnel area, but it was about as quiet & you had to think of it while stepping in to realize I pulled up the jute.
Side bonus it got rid of a musty funk the carpet pad held from a plugged sunroof drain that pretty much left the R side footwell with a stubborn funk I'd shot alot of Resolve & another brand into. And if your vents plug & flood that side again, once you go to dry the carpet only it's 1/4 the time to dry.
I'd do it again if say I'd bought a smoker's 80 & it had stubborn funk, among any other reason - you don't miss the pad at all. I was told it would wear the carpet backing out quicker, but I sold it ~18-24 months after.
If it was a dealbreaker I bet you could use norm residential backer & Super 33 it to either side. Just an idea, no experience. At least residential isn't a spitwad when wet like our stuff is.
X2 ditch it. I took my rug to the car wash and it made it a really easy job.
SNIP
Be cautious when using residential/non-automotive-rated adhesives on things, though. House floors don't get hot. Some that stay semi-flexible turn into a real mess if heated. And we know what happens to the temps on the passenger side floorboard.
I think you mean Super 77. Super 33 is electrical tape.
Super 77 holds up to heat just fine. I've used it for automotive purposes for years. Just recently used it to reattach the hood liner. It's been holding for a few months now.
Yeah, I was wondering what 33 was.
Good to know that 77 works. That's the first thing I was thinking of. I use it all the time on my model railroad layout, but was thinking I'd want to verify it would work for this application before relying on it. Looking at my can, it does note to not use it for "automotive headliners."
3M also makes 90, a hi-strength adhesive. It says "not suitable for bonding unsupported vinyl." Maybe like interior padding, seats covers? Maybe some else has experience with it or something else they can recommend?
Be prepared for the carpet to get heavy as s*** when wet. I washed mine in the driveway and it was a struggle to then get it over my clothes line to dry.
Did carpet clean up well? What happened w/the backing/padding?
You're right, that's what I meant -When indoors I post with a boxer (dog) staring at everything I type, so I only remember <75% of what I know when he's eyeballing me & any snack / drink within my/his reach. I goofed my 3M products.
When I washed mine, I just put a couple of ladders out and draped it over them so the air could circulate around and dry it out. Worked out well, but I really should have spent 2x the amount of time cleaning it that I did. Taking it to a car wash is probably an even better idea.
I scraped the padding off. It was like wet dog hair. Carpet cleaned up great. I used dish soap to clean.
Should get some nice liquid like this out of it. It took awhile to get it to the point of a "acceptable" water color before I called it quits.
I can add from experience working a car lot as a late teenager, if we chose to sell a trade-in that had horrible carpet, I was the lot kid who did it:
I'd pull the carpet, lay it flat on concrete & use a weed sprayer with Simple Green mixed in it (choose your own ratio / nastiness of carpet) - I'd spray solution & let sit 15-20 mins.
Then I'd add some hose water to a certain spot, working a 2' square area at a time, working from the highest part of the carpet as it laid on ground to the low spot / drain.
I used a brush that you get for wheel cleaning, the 2" bristle with a 3" square head, and I'd add car wash soap direct to spots I worked to lift out the dirt.
Once I'd worked over the whole carpet I would use the hose nozzle to power the grit from the high to the low again, litterally hitting every square inch along the way.
Then I'd make the same pass wearing safety glasses while using compressed air, the glasses saved eyeballs from flying grit (you'll be surprised) & using the rubber tipped handnozzle, the brass venturi type just spit air side to side.
The air helps, but it'll still be 2 days hanging before it's dry enough to reinstall, but it weighs little enough my scrawny 17-18 yo self managed to heave it over a makeshift clothesline I'd make.
One point I can add is the compressed air really lets some serious crap loose that you find ground in especially in the driver footwell where the heel pivots from gas>brake, it helps re-fluff the carpet & dries the carpet more than using a shop vac while spitting that fine sand loose the shop vac won't grab either.
The garden hose with a good nozzle & the compressed air to help fluff / dry carpet were the best ways I found to loosen / get rid of grit you otherwise don't get out.
HTH somebody.
HTH somebody.
Excellent advice
When I did mine at the car wash I did the backside first and blasted away taking all the insulation right off. I was lucky enough to have a pickup truck to toss it in.
I also did what Linus did afterwords with the cheap pump sprayer and some simple green and then wet dry vac'd it out.
