Pulling out Old PCV valve
Columbus, OH
Wanted to change out the PCV. Boy is it snug and hard to pull out. Any chance I break something if I pull too hard? Any advice?
Should lube with oil when I reinstall?
Nope. The PCV grommet is supposed to be rubber but has probably hardened. Just keep pulling. It's not attached to anything. Then take an angled needle nose pliers and start taking out the rubber grommet. It will probably come out in pieces. Be patient with the grommet so you don't drop chucks in.
If you have any redneck to you, make a crowbar to pull it.
It'll save you a chiropractor visit, will cost you a ~14" chunk of flat bar & 20 mins.
Mine was a rock on the seal @ 185K in the 450 - I dabbed RTV all around as preventative of loosing a seal collar chunk down the crankcase.
Make a wrench, bring a new seal for the new PCV, and it'll be easy.
Edit: As you can see by valve cover shape, I rocked my crowbar right at me, the valve cover is near meant for the job.
You won't hurt anything by putting some muscle to it. BUT the grommet will be difficult to remove, it WILL be rock hard and brittle and WILL break into pieces if you just go prying on it. I used a bare hacksaw blade to slowly cut two relief kerfs (180° apart) before removing mine (in two pieces) that way you don't have a bunch of small pieces going down your valve covers.
Good call. - we were thinking along the same lines (my RTV was to hold it all as a piece). At any rate, some preventative measure to try & hold the grommet or control the break-down will beat having to either pull the cover or wonder how that grommet gets into the oilpan for your next oil/filter change.
Like the relief cuts idea.
