EFI is Fuel injection. What you are looking for is the ECM fuse. The radio, clock are on the dome light fuse. Disconnecting any power or fuse should not affect your presets or your factory alarm. Disconnecting your battery for a minute or so will do the same thing but will reset your clock. Your code will come back, assuming you don't fix the condition that tripped it. If you are trying to get an inspection, after clearing your CEL, the vehicle will go into a NOT CLEAR state for a couple of drive cycles and assuming you have a 95-97 and they read the OBD port, they will fail you not ready, most likely. I don't think they read this on ODB1 vehicles and if you'd have the same trouble.
