1. Front pan arch.
2. Oil pump O-ring
3. Front crank seal
4. Crank position sensor
5. Timing chain cover
It is probably not the timing chain cover unless you see the leak higher up. It is probably not the CPS because the leak appears to be higher up. The most likely is the front pan arch but it is also the hardest to "fix" because it takes FIPG to reseal it and you have to drop the sway bar, the lower pan, the upper pan, and raise the engine. It is a pretty big job.
Clean everything up really good, leave the skid pan off for a few days, and see if you can find out where it is leaking. If that is inconclusive, get some oil dye at NAPA (~$5) and a 110v black light (UV light) and see if you can find it. You'll add a bottle of the dye to a quart of oil, then put the oil in the engine. Don't overfill the engine.
There is a picture somewhere here in the 80-Section where Cruiserdan showed where to put a bead of silicone to help isolate between a front crank seal leak and a front pan arch leak. Let me know if you need help finding that thread.
Zane has a nice thread on the R&R of the oil pump O-ring and the front crank seal.
If you decide the leak is coming from the timing chain cover then you have a big job. A really big job.
Forgive the newbness of this question but, how bad is this situation considering all of the options? I'm coming up on a trip mid april and wondering if should be addressed asap or can i give it some time?
Depends on if your mid-April trip is to the mother-in-law and she hates oil drips on her nice new driveway or if your mid-April trip is to the desert and a drip here and there won't be a big deal.
I didn't try to fix mine until it got to the point of about 10 drops hitting pavement every night. That got to be more than I could take. YMMV.
