Wanted PTO winch
Status
Not open for further replies.
Anyone have an original PTO winch they wanna sell? I'm in So Cal. Dreaming of having a winch on my 74 FJ40.
Thanks for the lead. Looking for more of an original condition. My 74 is a beater. Thanks
I have a complete PTO with driveshaft and transfer gearbox in Burbank. The only thing I’m not sure I have are the two spacers that go between the winch angle iron and the framerails. $1500.00. You can call the shop to follow up; no PMs please.
Mark, do you have the entire PTO setup for a ‘70 FJ40 3 speed?
Martin, it’s been many many years since I pulled this setup, but IIRC, it came off a ‘69 with a 3 speed.
In other words, yes.
Is $1500 pretty much the cost of a complete PTO set up? Sorry, very unfamiliar with it and the value.
My spacers are easy to get to right now, since I have my winch off the rig during the painting process. I could get some measurements off them if anyone would like to take a stab at making them.
I would be interested in getting some made. If you could send some measurements that would be great. Thanks, John
Could you maybe add a pic with those measurements? My pto doesn’t have em and would be nice to see what they are for reference..... i could prolly just search too.....haha
Thank you. So, you're saying $1500 starting point, and more?
For a complete set up, that's probably a realistic price. I know @HelloKitty65 has been buying his in bits and pieces, he might get into it for a bit less, but maybe not. And finding ALL the parts is tough if you can't get the whole enchilada at once.
@swamp-thing @pardion - Spacers appear to be cast iron. The angled side has a slight curvature to match the curve of the frame.
Width - 50mm
Depth - 40mm
Height - 15mm at tall end, 10mm at short end
Hole - 13mm diameter (for M12 bolt)
Hole is offset toward the thick end, hole center is 17mm from thick edge. Hole is perpendicular to the flat side.
How about the smaller wedges that go on the bolt before the washer and nut? Those are rarer than the wedges between the frame and winch.
I assume those go on the bottom side in the frame? I don't have any of those, but it makes sense that they would be a good idea. The taper should be the mirror image of the topside spacers.
I may need to make myself a pair of those...
Status
