PTO Winch Operation
Colorado Springs, CO
Hey I posted about a month ago about a new 1970 FJ I had just purchased and have finally been able to go pick it up and bring it up to Alaska. I have a newby question. When I was talking to the PO about the winch he said he had absolutely no idea how it worked and that some people who test drove it had messed with it. It looks to be totally complete but is not properly wound up on the front housing. I was searching and was unable to find out how to actually fully work the pto. :confused: Engaging/disengaging. Any help would be appreciated. Sorry if this has already been covered...
this what you're looking for? ;)
I guess I dont know how to shft the transfer because I only have the PTO shift knob. Underneath the dash I have a knob labled F.D. which is supposed to engage the four wheel drive. It would be easier to just post a picture.... Ill post one in just a min.
Hey Leemj...
Just give me a call at the shop and I can explain it to you easier than typing it out or taking pictures. It's rock simple.
I'll be here all night.
907.373.3789
Mark...
My PTO doesnt seem to operate like these instructions. The PTO shifter only goes back (toward the driver), it does not seem to have three positions. From the instructions it seems like pushed forward it should wind.
Mine only goes forward if I put it in reverse (with the PTO level pulled back).
Any ideas?
Thanks,
Don
Hey Leemj...
907.373.3789
Mark...
Something obstructing the linkage? Trashed shift collar? Post up some pics, particularly of the PTO (the part atached to the transfer case.)
I'll get more pics up tomorrow in the light, but here is the front...
Don
Has the winch ever operated? It could be the opening in the tranny hump is not long enough to allow the shift lever to go forward. It also could be the gearbox is incorrect for the winch. If you have a pic of the gearbox before the install, please post it up.
Also, your rig is so clean and nice, it hurts my eyes.
Peter
Don
Peter
So maybe I could get under the truck and disconnect the shifter and try and manually move forward? I guess that would be the simplest answer, although I am not excited about cutting a bigger hole. I will post pics of the gear parts tomorrow... I am certainly confused...
Thanks! Don
maybe I'm not thinking this correctly, but here goes.
What trans does the rig have 3 or 4 speed? if it's 3 speed linkage on a 4 speed trans, this PTO linkage would be tooo short thus only engaging in one direction
When the PTO is in neutral, is the lever straight up and down? It should be.
PTO gearbox
There are OEM Toyota PTO's out there that only have 2 positions, engaged and disengaged. You have to use reverse to play out cable. My '73 (April 73, with 3 spd) has one of those. I thought I was going crazy because everyone said I should have a Fwd and a Rev position, took it apart and I was right, there is only one gear in there, it is either in or out. Most of them have 2 gears and 3 positions (Fwd-disengaged-Rev). I have since bought a 3 position one to replace mine with, bolts right up.
The problem is opposite. I have to use the REVERSE to wind, not play out the cable... still puzzled, but I am going to get under the truck this afternoon.
Does anyone know about the 2 option shifters, to engage the winch do you push forward or pull backwards, this info might help...
Thanks again guys...
Don
