pto winch LHD /RHD
Jacksonville FL
Good day !
I have been avidly reading threads for a while. Great information.
I found an owner who says he has for sale a complete PTO winch, transfer case ?, drive shafts, mounting hardware but it came off a RHD (japan) BJ40.
Will this fit on a LHD FJ40 ? I am concerned whether positioning of the driveshafts and also the transfer lever inside will be a problem.
Would appreciate anyone's input.
thanks
PS it may seem crazy to consider winch before vehicle but pto winches are hard to find ?
I would be sure it is a complete winch. Also while RHD or LHD doesn't make a difference which model and what year does. One piece transfer verses split case transfer? Single or dual direction? Which driveshaft setup? Also which shift linkage? From mid 63 on all PTO winches import by Toyota were basically the same except for the three or four speed driveshaft. These would bolt on up to 1/79. After that need to research would is needed. At one time mid 63-1/79 were all that were available in the used market. Today parts are showing up from other markets all the time. A little bit of a PTO junky and done a little research on them.
Wow, thanks for fast replies.
Good to know LHD/RHD shouldn't be a problem but LITP's reply suggests I need to make more enquiries.
thank you both so much.
why not up to the 1981 introduction? 79 and 80 still had 1 piece transfer. or was it the funky exhaust routing with the cat that messed with the driveshaft?
Besides the way Toyota ran the exhaust under the frame in the US market (can only think the increased heat from the Cat why they did that) the PTO driveshaft mounted to the side frame rail like the FJ55. The holes in the front frame rail were offset because of the angle. The bracket for the radiator was no longer above the hole but closer to the center.
I'll have to check under the rad on my 1980, I don't remember if it's there or not.
I have a 82 FJ40 frame that doesn't have one either. Believe Paul's question is whether the 79/80 with the one piece transfer case had the tabs on the radiator mount to support the pillow block bearing.
correct that was my question, went out and looked and no I don't have the mount under the rad, also looks like the hole thru the front crossmember is angled to the motor mount, versus the hole on my 65 which is straight thru.
can't say I ever noticed the hole was angled or that there was a difference in the hole.
