peterb said:Mark & Poser
I've been looking around on the web. Seems to be two types of gearboxes. One has one drive gear extending outside the housing (this is what I have and is just engaged or disengaged) and a box with two drive gears showing. I presume the box with the two gears extending outside the top of the housing has the forward-neutral-reverse and is the one I need to fix the problem I outlined in my first post.
Thanks
Peter
The PTO drive box for the non-split case has two gears which protrude from the unit, one of which engages the PTO gear in the T/C. It is always engaged.
The box for the split case has a single gear which protrudes. It slides forward and backward and is only engaged when the PTO drive box is engaged.
A box for a split case will not mount on a non-split case nor will it work the other way.
Mark...
