PS Vane Pump or PS Gear box- which do I replace?
i checked the FSM. on page SR-21 there is the PS Vane Pump on and page SR-30 there is the power steering gear.
I have a bad leak someplace in there and now when I turn, there is a nasty creeking sound. My question is, which part do I replace? The power steering vane pump is my guess, along with the O ring that connects it to the gear.
any suggestions? i cannot seem to find exactly where the leak is coming from.
Hose it down with brake cleaner and inspect your steering gear frame mounts. That might be the creaking. As for the leak the HP hose assy could be the culprit.
The vane pump is your power steering pump and the gear box is your steering box. There are 2 hoses going between the 2 which can leak. Find the leak before you start throwing money around.
The groaning sound is more than likely telling you you're low on PS fluid. Fill the reservoir with ATF and find the leak.
option to rebuil both if you had a masive failure in 'em .. forget the idea of buying a new one from Toyota ( at least for my budget )
truck just failed texas state inspection. too much play in the steering and poor brakes.
lets just talk steering here. i have brand new OEM drag link ends and an aftermarket drag link from slee, these are installed. i also have OEM tie rod ends and a tie rod which i will have the garage install. the wheel bearings are all new less that 10K miles ago with a complete axle rebuild. trunion bearings included. what else can i be looking for? in TX they only give you 15 calendar days to fix it.
Play in the steering can be anything. Rod ends are common, but loosness in any of the suspension bushings cause this too. So can loose wheel bearings, bad trunion bearings, etc. In my case, the pan hard bushings were bad and this made fro very poor steering and occasional death wobble, now it's tight!
If you need a new steering box, Toyota wants $2500 + roughly $300 for a Pittman arm (needed because the new box has a larger sector shaft).
Leaking is likely the back of the pump or one of the hoses. It would be a good time to replace the pump and hoses. The steering gear box box rarely goes bad, so that's the last place I'd suspect.
thanks. i have new slee blue bushings in all the arms etc... i am at a real loss here.
Have you considered adjusting the steering box yet? There is a procedure in the FSM to do so. It's kind of a band-aid because once you get the center dead-band adjusted it will really snug up the remainder of steering travel. If it works for you to pass inspection it may be worth a try.
that is a very good point. i found it in the FSM on page SR-6 but i have no idea where it is on the vehicle. is it in the steering box?
yes, right on the top in the mess of PS hard lines
so while looking for that screw i found it. however, this lead me to the source of the big leak. its the steering box where the steering shaft (?) goes into the steering box.
is there a seal there? or is this indicative of something else like a new gear box? ugh.
the worst news is that this is at a shop which is NOT a toyota shop and its in pieces. :mad:
There is a seal there-a seal on the shaft and an o-ring on the body. Both can leak. It does not mean your steering box is dead. Just send it to West Texas Ofroad, who will reseal it and make it good as new for $150 or there abouts.
These steering boxes are stupid simple inside. I resealed an FJ60 box, and the 80 box is nearly identical. If you are worried about doing it yourself, you can pull the box out and send it off, thereby saving a ton of $$, and still having the critical part done by a pro.
Get that truck out of that shop. They are just going to burn through your $$ and fix it wrong in the end.
It's because they are identical except in different housings between the 60 series and the 80 series. The inner guts of a 60 series gear box will fit into an 80 series gear box with no additional modification...
  • Like
Reactions: RFB
ok... i went under the truck and found a loose bolt on the slee caster correction plate. the pass side rear was loose so i tightened that up. i also checked all the others which where secure. the welds there in the front are not cracked either so that was good.
i also adjust the alignment a bit to bring it more on center.
lastly, i tried my best to adjust the steering box but it looks like i need about a 24" flathead to get it done while it is still on the truck! i tried. i am about to take it out now to see how it feels.
WOW... I have this same problem right now. See "Now its a power stearing leak" I think you guys just solved my problem. And you right. I stopped by my local shop today on the way home. (Good guys, but not LC experts) A near gear box is 2500.00 bucks. Now im going to try and find a local shop to replace the seal.
Anyone know a shop that can do this in Phoenix?
