I'm in process of re-building my PS pump. Its been leaking for a while; finally decided to get a seal kit and just replace the seals myself.
I carefully pulled apart the housing; but before I could get a look at the springs...everything fell apart
I have figured out how the springs were set up; but I'm not sure which direction the top cut-off piece goes. To make matters worse, I only have 22 springs; should have 24; ie 4 springs x 6. Looked all over, in case I dropped something; but that was not the case. Is that a major issue? Can two of the brackets have only 3 springs?
What's the best technique of putting this back together again?
Any advise would be much appreciated.
.I have figured out how the springs were set up; but I'm not sure which direction the top cut-off piece goes. To make matters worse, I only have 22 springs; should have 24; ie 4 springs x 6. Looked all over, in case I dropped something; but that was not the case. Is that a major issue? Can two of the brackets have only 3 springs?
