I wanted to start this thread to document my FJ40 build and some of the technical details I have been working through specifically related to adapting the A750 to the split case. There are now several successful 2UZ/1UZ swaps that have been completed but I am not aware of any that are using the split case.
Build Plan
Background
My dad bought this FJ40 in 1997 when I was a freshman in high school. It was a father/ son project and we spent a lot of time fixing rust damage, repainted it, and it was my daily driver through high school and most of college. I did some minor modifications to it over the years including lift springs and shackles, Saginaw power steering, header and exhaust, and swapped in a H42 and split case from an 82 FJ60. I always had plans for additional modifications to it, the plans evolved over the years but revolved around adding more power, bigger tires, better suspension, more stability (width), etc. I always struggled to find the money and time as I was building a career and raising a family so I slowly gathered parts and the cruiser basically sat in my shop gathering dust. Last year I came across a wrecked 2006 4runner and decided to buy it which finalized the plan for the drivetrain.
Stability as an objective of the build lead me to needing wider axles and an extended wheelbase. I picked up the 80 series axles a while back, the rear will probably get upgraded shafts, locker and gears (probably ARB & 4.88 but TBD) while the front is a hybrid build with 80 knuckles on a SF 80 rear housing, the short side inner axle shaft is longer than stock so I should end up around 67” WMS. I decided not to mess with leaf springs and go straight to linked suspension, the plan for the wheelbase is to move the front axle forward 2-3” and get the rest of the stretch in the rear. Along with the mechanicals of the build I am planning on new seats, roll cage, adding AC, and a FJ60 tilt steering column. I am trying to keep this as Toyota as possible which is why I have chosen some of the components that I have.
Build Plan
- 1979 FJ40
- 2UZ-FE 4.7L V8 (06 4runner, VVTI), A750 5 speed automatic
- Split case transfer case with 4:1 gears
- FJ80/ 9.5 hybrid front axle, FZJ80 FF rear axle
- FJ60 steering box, hydro assist (RHD steering arm, Y-link, 1 ton TREs)
- 3 link front with coilovers, 4 link rear with coils
- Stretch cab and frame (15-18” stretch, 108-110” WB)
- 40” tires
Background
