Lemme reiterate what @NCFJ said .... careful not to go to the floor with the pedal. Can either ruin seals in the MC or tear the aged diaphragm in the booster.
Trying to get running. It sputters and seems like it wants to run but is really rough. Johnny helped me install the dizzy so I'm hoping we both didn't do it wrong.
New cap, rotor, wires plugs, coil, almost everything.
I have fuel and I guessing spark as its sputtering. I DO have oil pressure...which is what I was concerned about, not it not starting.
I swapped plug wires 6 to 1, 5 to 2 and 3 to 4 thinking it was 180 out maybe. It didn't do anything trying this way, but maybe it was flooded? My shop smells like gas but mainly since I had a loose hose and s*** leaked on the floor. No leak now tho.
I was able to get the truck to run with the dizzy rotated counter clockwise as far as possible. I may be a tooth off. I purchased a timing light last night and it should be in tomorrow. This is the one i purchased --> Product Detail Was ~70 bucs shipped via amazon. Having the digital rpm should make tuning the idle super easy...not that I think I need to with a newly rebuilt JimC carb.
After pulling the truck back into the garage last night I think I've remedied my clutch and brake fluid leaks.
Plan to order some one-way vacuum valves for the distributor vacuum lines (thanks for that pointer @Trollhole ). Don't want exploding distributor cap.
Will be checking and marking all bolts...thanks to those that found some loose ones...whoazers...then finishing up small stuff, installing soft top and enjoy it!
When I put it back in the garage last night I tried 2 low in the granny gear...so cool.
Leaning toward one 5lb h3r maxout extinguisher (abc type) and one of their 2.5 lb halguard extinguishers (clean agent). H3r also makes a nice an 'extreme duty' mount that should fit a roll bar.
