Project Arms Flipped Complete
SLC, UT
First of all a big thanks to everyone out their that helped me with questions... tools, slee, and everyone else!
I have finished for the most part my lift. Slee 6" med. rears and 6" heavys in front, slee SS brakelines, pro comp 9000 shocks, adjustable panhardrods, extended bumpstops, extended swaybar.
Things still needing to be done; front DC drive shaft (I have some good vibration), rear upper ajustable arms, ajustable front panhard rod. Front bump stop drops.
The install went very well I basically copied the castor setting from stock. I have not taken it in yet to have it professionally read, but it tracks strait and feels the same as it did before on the freeway. I love the extra clearance it gives me untder the axle. It was a pain having to re-rout the ABS lines and the rigid brake lines. and lots and lots of time making sure the front axle got seated correctly under the truck.
Some issues that I still need to solve;
The sway bar hits the tie rod in some situations. Right now I have dropped the mounts and re attached the brackets at the axle under the ned arm mounts, any suggestions welcome.
I also am not sure I will have a problem with the front radius arm hitting the front panhard rod. I have tried to flex it out and it did no hit but I am still a bit concerned about it.
Any front shots showing the whole front of the truck?
This looks cool.
wow! nice job!
any issue you think about having lost the control arms as "skids" under there to protect the other stuff, like the transverse rods etc?
wow! nice job!
You have a good point, but the arms on the top still provide some "skid" effect. I am not too concerned about the transverse rods as it is so close to the axle. The only linkage that could be a problem is the sway bar.
good deal. i had thought about this approach a while back, just didn't have the tools or money to make it happen. Look forward to hearing your opinion on if it was worth it.
Can we also get a kind of write up on what you did to make it work? I'm assuming you had to move at least one of the mounting points and re-weld, no?
It accually saved me money, verses buying new arms. I also will have better flex, better suspention geometry, it will climb better, same wheel base, it handles very nice on the road, and increased ground clearaance. So all those options pushed me over the scale into trying it out.
I had to use all new mounting brackets. I tried to cut the factory ones off, but they got too mangeled and would require some modification, so I cut them off all together. I still have a bit of cutting to get the last bit off but, I figure this will be one less hange up point under the axle.
Bascially, what I did was I took a hi grade protractor and took an angle reading off of the (2) large bolts located on top of the axle (trinion bearing cap) and did this at both ends of the axle. One thing that I did not do, that I should have is; I should have taken it to get the castor read before the change to make sure I did not have any problems with castor from the start. The method that I used will just transfer the exact measurments that I had before. I took this reading at both end of the axle.
Next, I measured from the ground to center of hub with the wheels on. Then I took the wheels off and set jackstands under the axle to that same height. Then bracked the frame of the truck up so I could have the axle floating freely for working and for safty.
I thought about keeping one of the arm one to help keep the axle centered, but after I put the new 6" spring in, both arms need to come off because of caster and wheel base changes. I then put some weigth on the springs and set the castor/angle back to what I had when I started. then I took a wheel base measurment on both ends to make sure the axle was square under the truck. This was the most difficult part for me to get set. One trick that work well for me is I got a 1" x 1/4" x 3' bar stock and placed one end just at the base of the nuckel (I took a calaper measurement to make sure both sides of the axle had the same thickness at that point) then at the other end I put a mark at the center of the bolt hole at the rear mounting bracket for the front control arm. I then had a template to use. I then went to the other side and adjusted the axle with my new templete untill each side matched up exactly.
Once I was happy that I had trasfered the castor and the axle was square under the truck and I had the correct wheel base. I made a template of each mounting tap that was to be welded into place to attach the front end of the control arm to the axle. 8 tabs in all and each one was slightly diffrent so it would fit perfectly on the axle. As I went along I continued to check my measurments to see if the "pull" from welding moved anything. After I was done I just bolted the arms back on tight.
One headache was adjusting and remounting the ABS lines. I welded in new mounting tabs to bolt the abs harness to. On my truck the abs line ran on the outside of the DS. control arm. I was able just to use the same mounts and run it back onto the inside of the arm. The ridged brake lines needed to be move slightly, and with some carful manipulation I was able to make them work basically in the same place. The factory pan hard rod just got bolted into it factory mounts. It looks like I will be close to making some contact with the arm under extreme flexing situations. I will wait to see if I need to get one made with a larger bend over the arm untill testing is done. I am hoping it will work as is, then all I need to do is add Slees do it yourself adjustable panhard rod kit to adjust it back to center (3/8" is all it needs to be lengthed). The last problem is with the mounting location of the sway bar. I think If I did not extent the bar mounts at the frame down 2" I would not make any contact. I had to mount the tabs for the sway bar at the frame under the new arm location. This bug looks to be an easy one to fix.
not trying to get off topic, the suspension looks good, but is that brush guard allready mashing against the fender flare?
Ya it is, it is being replace with an ARB soon. Like I said I have a long list of things I need to do to pritty it up. Just thought I would get the suspention out of the way first.
Man, some diff armor may be in order now, that looks great like that! (but the diff looks really exposed!)
For your swaybar hitting the tie rod, you can mount your tie rod ends on the bottom of the steering arms instead of on top. Of course that means reaming out the other side and permanently altering them but used ones abound and are cheap if you ever wanted to go back. At that time you can also use a beefier tie rod by sleeving the one you have or getting one in thicker walled tubing. You can also jump up to using 1-ton GM tie rod ends or heims. It will effectively move the tie rod down ~1.5" and may be enough to solve your sway bar clearance issue. Having it down that extra 1.5" will not likely increase the chances of it getting bent or destroyed either. I've repeatedly hit mine (0.25" DOM) and it is still straight.
And as Dusty alluded to, the actual flex isn't any different than the original arms since it is attached to the frame and axle the same way, just higher. It may behave better with the amount of lift you have as it cycles since the arms are probably in a better position at static ride height but I'd be surprised if you actually get "more" flex out of it. But please ramp it on something and take some pics with a tape measure. Also, how much travel are the front shocks you have on it? 10"-12" of real shock travel would be great.
Great project :cheers:
That is great idea about the tierod / sway bar conflict. I have some heavy walled DOM that I used on my 40 left over that would be perfect. I would get the clearance I need and have a beefier rod. Thanks for the idea! Would I just wobble out the hole with a drill bit? or what would you suggest?
My shocks have 12" of travel so they should help with flex. I will get it put on a ramp as soon as I can.
Well, the "correct" answer is to get the proper reamer for the taper of the tie rod end you'll use. I ended up buying one for the GM 1-ton stuff since that is what I wanted to go with. Good reamers are north of $75 but it is nice to use the right tool and have the results end up being what you want ;)
https://forum.ih8mud.com/showthread.php?t=61575
Thanks for the Idea and the link with all the info an part numbers. That will be my next course of action.
Good looking front axle by the way.... did you use Gloss black?
