Project Arms Flipped Complete
I had to use all new mounting brackets. I tried to cut the factory ones off, but they got too mangeled and would require some modification, so I cut them off all together. I still have a bit of cutting to get the last bit off but, I figure this will be one less hange up point under the axle.
I think If I did not extent the bar mounts at the frame down 2" I would not make any contact. I had to mount the tabs for the sway bar at the frame under the new arm location. This bug looks to be an easy one to fix.
Jason
Great work dude! I think you do indeed have more down travel, IIRC, the up travel is limited by interference, not the bump stops, yes?
For the swaybar, I'd just drop-block-it, and add/subtract end link length till it clears. Those blocks really only locate the bar pivots, they aren't really stressed that much. You can also look at getting a custom bar bent up by Addco in FL. I think the one in the 80 is pretty complicated because of the front arms below the axle. You could change the geomtry of the steering linkage, but that seems too much for what you are trying to do. End links are pretty much standard issue, so you have a variety of lengths to choose from at your local parts store.
Recalling being embroiled in a lot of geometry discussions on this as a 'virtual' mod a year ago. Amazing to look at the truck with it done, it looks so much cleaner, and it should handle on the road better, without the loss of off road manners.
When I calculated this out last year, the caster angle shouldn't change much if at all, you just reverse the arcs of the wheel vs a low mount arm vs wheel travel. IIRC, you effectively negated 3.5in of a 6in lift. You can PM me for my drawings on this. Those 'old' arm tabs look like a perfect mount for a diff protector/axle stress bar ala NWOR.
Nicely done, looking forward to the subjective driving impressions!
Cheers
Scott J
94 FZJ80 Supercharged
