Progress
Emigrant, MT 59027
Bought Fiona Joy a little more than 3 months ago, coming along.......... Finally got the gas tank reinstalled and can see how she tracks since adding the 6 degree shims...... better. Steering question........... when she sits parked, the wheels are straight as is the steering wheel, but when we drive down the road, to keep it straight i have to move the steering wheel a quarter turn to the right. Steering box problem, tie rods, ????? Input is greatly appreciated. She has a 350 chevy engine, so steering is not original, also has a power steering addition. Before.....
Have you driven it with the shims installed? Does it track straight and not wander going down the road ? You may just have to adjust the drag link to center the steering wheel. I see washers and what appears a stock 40 tre attached to the GM style pitman arm. Generally, the tapered hole in the GM pitman arm is much larger than that of the stock 40 tre. You could have a lot of play at that joint if a bushing hasn't been installed. Have someone shake the wheel while looking at that joint and look for movement. Usually, folks get a special Tierod that accepts a stk tre on one end and a GM tre at the pitman arm.
have driven less than 5 miles since shims were installed. Still some wander, but before i literally felt like it was going down the road sideways. Thanks for the input
