Where is the immobilizer ECU in a 1999 FZJ105
Great forum!
Usual story, last year I purchased a 1999 Landcruiser FZJ105 Snowy (Australian) from a dealer, and I only have the valet key (checked it using Charley's instructions). The key is a like a 4cs Landcruiser 100 Ignition Key, but with a longer blade (see pic).
Since my wife and I both need to drive the vehicle, I need more than one key.
I wanted to get the ECU replaced so that I can get new master keys, but I don't want the hassle (and cost) of going to Toyota so I worked out a plan:
1. I picked up a used immobilizer ECU from a 2000 HZJ105 model on
ebay which came with a full set of master keys (pics attached).
2. I want to swap the ECU from my vehicle with the used one - that way I will have a set of master keys coded to the immobilizer (obviously the keys won't unlock the vehicle or ignition).
3. I can then cut open one of the master keys and remove the transponder and swap it into my existing key (which will unlock the car etc). I should then have a working master key that I can make copies from and code to the ECU.
I think this should work, I have opened up an old Landcruiser key and found the transponder, so I think it should be pretty straightforward.
I do have a problem though. I can't locate the existing immobilizer ECU!
I've looked through a 2003 manual, and it's not in the same place (behind the glove compartment, above the engine ECU?).
I don't know any Toyota mechanics that would help me out.
Anyone know where the immobilizer ECU should be?
Or does my model have the immobilizer incorporated into the engine ECU?!
