Productive and expensive week
Visalia, CA
One week of upgrades and I'm on a budget for a year. Winch came first, Warn M8000. Install was not to bad of a one man job even considering that I had to take it off three time to get it right. And yes, it is heavy.
I did not want to go dual batteries just yet but I needed power for the winch. I got one big a$$ deep cycle Odyssey battery and installed in just a couple of hours. This of course included the trip to Pep Boys and Kragen auto parts. The battery weighs in at about 80lbs, what a tank. I was quite surprised when the thing fit in almost perfectly the first try. The tray on the fender side needed a little trimming. I ended up trimming about 2 inches x 1/2 inch and she fit perfectly.
Now that she was in her spot it was time to deal with the terminals. To my surprise, the positive cable already had ring terminals on all the wires attached. The negative cable was not as nice to me, I needed to either cut and solder a ring type connector on it or put on a terminal stud adapter. I bought both types at the store as I really didn't want to solder for fear that my breath would ignite next to the torch. Well the terminal post adapter was nice but the hood wouldn't close.
Everything works, I think! You will note that the original battery retainer does not exactly fit. It is really close to being perfect, about 1/2 to 3/4 inch short. For the time being I just put the one side on and used two monster zip ties to secure the bracket to the battery. This keep the battery from going up and down but the one side will still slide back and forth a bit. I will see what I can do to splice in more space soon.
Can't forget the wheels and tires
Well the wheels and tires were an easy install, somebody else did it. But now the rake looks weird. An ARB, Winch, and an 80lb battery makes the cruiser sit low in the front. Even with J's in the front and Heavies in the rear, it still sags. Ordered some 1" spacers from Slee and I hope that puts right again.
Now, THAT there is a battery my man! Nice job.
On the battery retainer thing, you could use a simple angle iron from Home depot cut to fit. Straighten the ends in a vise then drill two holes for the J bolts. Just an idea.
