So I’ve currently bought a new slave cylinder and have bled the line out quite a lot so there is no bubbles what so ever and now I’m having trouble getting into first and reverse while stopped it will only go in if I really use force for reverse and then from reverse go straight to first with some pressure, so I’ve been told to bleed it more in which it helped with the other gears but not these two I also got told to check and make sure the cylinder is moving in which it does because I can change to every other gear perfectly fine. I’ve been told to take the gear stick from top out and have a look at the syncros for first and reverse to see if they are bent I’m still in the process of doing that right now just wanting to know what your guys recommend, I’m also replacing the gearbox oil tomorrow just wanting to know what the best oil is for it? I also live in Australia QLD cheers.
