Problems doing a compression test
Texas
What the hell am I doing wrong? I’ve tried both a Mac tools compression tester and the cheap rental at O’reillys. Both of them won’t build pressure. It shoots up during the compression stroke, then goes back to zero. It does this on all 6 cylinders. What am I doing wrong?
Like slow95z says, if the gauge goes up and doesn't stay, then you're not using the tool correctly and there must be some sort of bleeder that needs to be closed.
There is often a Schrader valve in the part which screws into the head. Could be missing, loose or defective.
I’ll check the blender out. It’s weird it’s happening on both compression gauges.
No Schrader valve in the damn hose. Cylinder 5 & 6 are dead. I can actually hear the pressure from one cylinder coming out of the other.
