Hey fellas, I've had a persistent problem for the last few months that I've put off diving into. My blower/fan for the AC/heater only intermitenly works. Over the summer it has seemed to randomly either work or not work (on every power setting including High, both heat and ac). I might press the button and it works for a while while driving then if I stop and shut off the ignition, then put the key back in and turn the vehicle on, and the blower doesn't work.
Now that the temp. here in PA. is getting cold (espesially in the morning, mid 20s) I need this to work for me so I can use my defrosters. What I have noticed lately is that it seems to work when the engine is cold-thank god every morning when I wake up for work the blower works
Then I'll drive 15 miles to starbucks, get my coffee, then get back in my 80, and the blower/heat doesn't turn on. Also, when I park my 80 at work or at home for the night I have made sure one of the blower settings is turned on (when the blower isn't working, like it should). Then several hours later when the car is completely cooled down, I'll put the key in the ignition, turn the key to "on" and bam: blower turns right on (because I left it on low, med., high setting)
So the blower seems to shut off when the engine is warm/hot, but never has shut off on me while I've had it turned on. It always happens when I either turn the 80 off, or turn off the blower, then try to turn it back on.
I hope my explanation has made sense to you all, and I've included helpful info. I have done a search on this and I really havn't turned up anything. Thanks for everyones help, I have the weekend off and I plan to try and work on this and fix the problem.
