Problem- ABS engaging just before every stop
Has been happening on my 97. Only happens as i am about stopped. Had a blowout a few years ago and my sensor was hit. I got another used sensor from cruiserparts and it too had a small crack in it! Pulled the abs fuse and had'nt done anything untill i found a siezed piston in my front ds caliper. Rebuilt that and hoped it would fix my abs problem. It did not! Now i am doing an axle swap so i will swap the abs harness and see what happens!
This happened to mine. Was about to leave for a camping trip and on my walk around noticed a hot brake smell. The side it had been pulling toward was dragging in addition to it pulsing when coming to a stop. That added heat loosened the star washer the PO had butchered. So, after all was remedied in the front end I deleted my ABS module. Best braking I've ever had in the 3 80's I've owned. Look into that.
X2 what tools said. Clean first or replace faulty sensor.
Just clean
Remove the wheel, remove single 10mm (?) bolt securing the sensor. Wipe off and reinstall.
