For Sale Price dropped to $9,700 - 1994 LC 80 series, Twin Cities, MN
Starbuck, MN
Year
1994
  1. 80 Series
Mileage
215000
Color
Silver
Outside Link
https://www.facebook.com/marketplace/item/921364649232171/
$15k OBO. $12k. Really nice, stock, rust free, exceptionally well sorted 1994 Land Cruiser for sale – not triple locked. 215k miles.
No underbody rust or body rust (aside from superficial surface on axles shown), very well sorted, excellent running and exceptionally nice cloth interior. Truck is recently from the Pacific NW.I really hate to sell this thing, but I have a new financial priority and I own three land cruisers already, so it’s hard to justify keeping this thing even though it’s really a rare gem.
Tons of work done in the last 9 months to get it well sorted (by previous owner) (in no particular order):
- New Yokohoma Geolander A/T (basically brand new) 275/70R16- Real wheel bearings, axle seals, gaskets- Front knuckles rebuilt- Rear shocks- Front shocks- New OEM Toyota battery- Steering damper- Water pump- Crank seal- Oil pump cover gasket- Exhaust manifold studs- Radiator hoses- Coolant flush (Toyota red)- PHH reroute- All hoses- All hose clamps, gaskets, o rings, etc.- Heater control value- Thermostat- OEM radiator cap- Front brake calipers- Front brake pads- Rear brake pads- Wipers- Fuel filter, fuel cap- Oil pan gasket- Valve cover gasket- Spark plugs- Spark plug wires- Oil plug drain gasket- PCV valve (and grommet)- Plug seal gaskets- Fuel injection throttle body mount gasket- Fuel pump strainer- Fuel tank cap- Fuel vent hose- Batter clamp and bar- Distributor cap- Distributor rotor- Alternator belt- Drive belt- Throttle cable- Transmission flush and fluid- Front differential, rear differential and transfer case fluids changed- Plug gaskets for all fills- Brake fluid flush- Full new exhaust system- Drive shafts / ujoints greased- Front differential rebuilt- Tie rod ends and drag links- Pretty nice stereo system with Bluetooth, hands free, big screen etc.
The negatives:
1. The sunroof leaks under pressure washer (not in the rain or normal conditions, but if you aim a pressure washer directly at it, a little water will get through. The seal around the glass has shrunk slightly with age and that is the cause.
2. There is a very minor rear main seal oil leak. I had it into a Toyota specialist and they advised against repairing it due to the superficial nature of the leak. I basically never drive this truck and the leak has amounted to a drip less than the size of a dime after sitting in my garage unmoved for over a month. That said, I personally hate getting surprised by a car deal and I want to be totally upfront with what I know about this one.
3. Body - The paint is good in most areas, not amazing in others. Theres a scratch down the passenger side, a dent in the drivers side rocker and hail damage on the hood. The rear tailgate looks to have received a bad spray over at some point in its life, but I don’t know why – there’s no evidence of body work. There are scuffs in other areas. It’s a 7-10 foot vehicle, I would say.
do you have the records for all the work and does it have a hitch
I have all the records, yes. I don't have the hitch.
Edit: Also, I dropped the price to $10k. I am going to pull it tomorrow 2/17. I was looking for funds for a project, but if I don't see it by then I'll take the money from elsewhere and keep the LC.
Great rig really good price... GLWTS
