Pressurized power steering line
Calgary, AB Canada
Where does the u-shaped part of the pressurized power steering line mount to the frame? An image would sure help.
Hope this helps.
Once you get under your truck, you'll see that there is a factory clamp bracket that uses 2 bolts, and rubber grommets to hold your "U" tube to the frame. The easiest way to change this is remove the old hose, and "U" clamp bracket from your truck as a unit. Then take the "U" tube bracket, and grommets off the old hose, and mount them to your new hose, then remount the new hose, and bracket back on your truck.
